The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
448 Questions View all
MacBook Air 2013 keyboard and trackpad frozen while working
I have been using my MacBook Air since 8 years, it has been having an issue with its keyboard and trackpad at the point where it stops responding while working. I have never spilled water or anything on it and this machine has no parts replaced and works great. If you heat it up it starts working once again, is it a hardware issue?
3 Comments
I would check your battery, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
by
@danj I did it, now what?
by
I had the same problem and it was just a little click in accessibility to fix it. Remove click on mouse keys to deactivate the issue of mouse keys and the keys are back in work 😀
by
Add a comment
Most Helpful Answer
Its sounds like a hardware issue,
I think its the trackpad thats the problem,
the keyboard plugs in to the trackpad,
so i think its that
heres the part:MacBook Air 13" (Mid 2013-2017) Trackpad
Replace a scratched or malfunctioning trackpad compatible with a Mid 2013 to 2017 MacBook Air 13" A1466 model laptop. Image
Product
$49.99
Score 1
Add a comment
Sadly Between cycle counts and just age, your battery is on its last legs ;-{
Time to replace it! MacBook Air 13" (Late 2010-2017) Battery and here’s the guide to put it in MacBook Air 13" Mid 2013 Battery Replacement
An aftermarket replacement battery compatible with a MacBook Air 13" laptop. Image
Product
$69.99
4 Comments:
But how does it relate to the keyboard and trackpad being unresponsive?
by
@honda_fanboy - The battery swells which then presses on the cables and parts causing issues.
by
i guess it could be that
by
@danj Thanks, I am actually planning a battery replacement in less than 2 weeks because of shipping, the battery is currently at 916 cycles
by
Add a comment
Add your answer
Steven Parker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 90
