The fourth-generation Surface Pro tablet, released October 26th, 2015.
201 Questions View all
Can you test it with out the battery?
I replaced the battery but the surface pro will not turn on. If I take the battery out can I test the rest of the surface pro by just plugging it in to see if it will turn on? Or if there is a guide on how to use a multimeter on the board to test it I am willing to try that. Thanks for any help.
Add a comment
1 Answer
It will run only from your Power Cord, I‘ve tested it. So if it still doesn‘t boot up, there must be some other problem.
5 Comments:
Thank you for the update. It looks like there are other problems then.
by
Have a look at the usual problems with this machine as mentioned on this site: https://www.aonemobiles.com.au/2020/03/m...
Hope you will find the problem!
by
Does the surface pro 4 works without a replacement battery in it, only with the power cord?
My battery has swollen, and it's too expensive to replace it in my country, so i am considering removing the old one and keep using the laptop as a desktop
by
I am in the same situation @moquedami , did you find out if it is possible? If so, did you try it? Thanks!
by
@pachi & @nahuel
As I mentioned at the top, it will run without a battery attached.
by
Add a comment
Add your answer
Jake Snyder will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 275
