Released June 2017, the iPad Pro 10.5" replaces the 2016 iPad Pro 9.7".
145 Questions View all
iPad Pro 10.5 (2017) suddenly stopped charging
My 2017 iPad Pro (1709 wifi+cellular) died and stopped charging suddenly. I use it for light tasks such as office applications and media consumption and I take care of it.
When I connect a charger, it shows a charging sign on the screen for a few seconds, however, the battery does not charge.
Took it to 2 different repair shops (unfortunately i don’t have access to Apple authorized service provider) both could not fix it and recommended replacing the logicboard.
My question is: Can I replace the logicboard with 1701 (wifi only version) logicboard?
1 Comment
thanks for the response and recommendation. will give that a try :)
by
Add a comment
1 Answer
Chosen Solution
You should be able to replace it with the 1701 version but if I were you, I would send it to someone who specializes in microsoldering. They should be able to diagnose and replace the damaged component on the board that way you can keep your data. In my shop, I personally use Jesse Cruz from VCC Board Repair for board level repairs that I’m not capable of performing and he’s very knowledgeable. There’s also Jessa Jones from iPad Rehab and she too is a board repair specialist. And both Jesse and Jessa have youtube channels you can check out. Heck Jessa has made a couple of appearances here on iFixit as well!
Score 1
Add a comment
Add your answer
malmalla will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 523
