The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
163 Questions View all
Xbox One X overheats on every game
I bought a used Xbox One X from a local game store, and every game I try turns off the console after a few minutes and gives a ventilation warning when it starts back up. The store wouldn’t let me return it so I took it to a repair shop, and they cleaned the inside (or what they could, they said that it was immaculate and no dust at all) and replaced the thermal paste, and checked that the fan was working fine, but they still weren’t able to get it to work. I’m a little desperate at the moment, so are there any suggestions to what I could do to fix this?
Add a comment
you could maybe try replacing the main board. also when you got the cover off check were the heat is coming from. that will help guild you to the solution.
Add a comment
If the console is clean from inside as well as the ventilation vents, and the thermal past/pads are replaced/in good condition, and the cooling fan is running properly, Then its mostly the heat sensor which is built inside the APU, Which is unfortunately unrepairable without replacing the APU If its available on aliexpress or ebay, or the motherboard itself, which doesn't make sense and i consider it beyond economical repair, your better off buy another console.
I'm sorry for the unpleasant experience you've had, but the shop you've bout it from has cheated you, reliability on the other hand is something that has never been associated with Microsoft consoles too.
hopefully you can get another one soon.
Add a comment
Add your answer
Lucas McIntire will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 188
