cant print with 3D
Hi Please help my printer starts after heating but crosses the table infront while depositing plastic then goes to the middle but the nossele stays 10 mm above the glass and just extrudes from there
What Shapes Cannot Be 3D Printed?
If you didn't print out one of these it could be a problem with your 3D printer. Try a teardown to see if that helps.
what 3D printer you have? If it starts 10mm off the build plate then there’s probably something wrong with your starting gcode. check your start gcode or check you limit switch which may prevent the nozzle from going further down if its not set correctly.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 64
