Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
Should I down clock my RAM?
Hi, I have used DDR3 at 1333MHz from a 2011 Macbook Pro. I'd like to upgrade a 2008 macbook unibody which bus is clocked at 1066MHz.
I've been told that there will be no problem doing it because the RAM will run automatically at the bus speed, it is true ?
Is there any way to "down clock" the ram frequency ?
If there is, what would be the best alternative ? clock it down or let it at 1333MHz ?
Thanks
Score -1
Add a comment
1 Answer
Chosen Solution
It very well might run at 1066MHZ, but mine runs at 1067MHZ for some reason
If they used 1166 in the factory by mistake(doubt it), it could be running it at the max speed for me
Try it without underclocking first
Score 1
3 Comments:
Thanks, I'll try tonight.
by
It does work correctly until now
by
If you start getting kernel panics, look to the RAM first.
by
Add a comment
Add your answer
Ben will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 20
All Time: 1,193
