LED Light Bulb Replacement
The LED light bulb on my 1500 lumen Ozark Trail flashlight was physically damaged, and in need of repair. Is it possible to have the bulb replaced? If so, how?
Add a comment
1 Answer
i’m sure there is a way to replace the bulb. the problems you’ll encounter though,
proper tools to open the flash light without damaging it
the right LED to replace it
do you have the soldering tools to replace the LED
if you have a way forward on that then you should be fine!
Add a comment
Add your answer
Joe will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 23
All Time: 1,081
