The Samsung Galaxy Tab A 10.1 is known by different models depending on the features. Regular model: SM-T580 (WiFi), SM-T585 (3G,4G/LTE and WiFi) released in May 2016 or S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new high-end “A” series.
108 Questions View all
Backlight Not Working After Replacement Parts
Hey everyone i have an issue with this tablet, it was dropped, I have replaced the screen, ribbon cables both the primary and lcd ribbons, the charger port, the battery and yet I can hear the tablet works, the touch screen works but there is zero backlight and I know the screen is working in a previous tablet, im at a loss at why im not still getting any backlight on the screen.
Add a comment
1 Answer
Most Helpful Answer
Hi,
Try shining a torch at an angle close to the screen and check for images when the tablet is on. They will be very faint if they are there so trying in a darkened room may help to see them.
This is just to verify that it is only a backlight problem.
If there are images then here’s the relevant troubleshooting section from the SM-T580 service manual that may help.
Also check that the LCD cable systemboard connector pins aren’t damaged or bent etc.
Score 1
Add a comment
Add your answer
Chris Watson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 290
