Learn about the skills that you might need to work on your device.
Repair/replace HDMI cable e nd
I am looking for a referral for someone who can replace an HDMI cable end. I am located in West Palm Beach FL area. (Please see links below for description)
https://www.amazon.com/dp/B08797WT7R/ref...
https://www.youtube.com/watch?v=Xub0l9s8...|video
Add a comment
Most Helpful Answer
Hi @elmo1234 ,
Hopefully there is enough slack in the cable to allow for a new connector to be wired in.
Here’s a video that shows how to wire a HDMI connector that may help.
It also may depend on what type of HDMI connector is being used.
Connectors are also available from here and here (supplier examples only)
if doing this yourself seems too daunting contact a reputable, professional electrician who also does data, TV wiring, security installations etc and ask for a quote
Score 2
Add a comment
Hi @elmo1234
Referrals are too subjective and are usually not acceptable on ifixit as it is mainly a DIY forum where people can offer advice on what you can do to fix the problem yourself.
Here’s a link to some services in your area who may be able to help you.
Check their reviews and then go with the one you prefer.
Moderator.
Score 1
Add a comment
Add your answer
Wayne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 316
