Fan suddenly stopped working
Hello,
My sister has a Zennox 18” Metal Box Fan that suddenly stopped working. It’s one of those floor fans that are quite powerful. She said she’s had it running continuously and one day she woke up and it was off. She tried turning it on, but it would not come back to life.
I’ve tried turning it on myself and it’s completely dead. There was a lot of dirt/debris on the fan and on the circular metal part the fan blades connect to. I thought this was the issue. I cleared it all off and tried to power it again. Still dead.
When I try to turn it on, it makes no sound. It’s not even trying to come on at all. This made me concerned from the get-go.
I researched on Google what might be the problem and it said there’s various culprits. I first checked the capacitor to see what uF reading I get with my multi-meter. I took it out and tested. Multi-meter gave a consistent reading of around 1.5uF. The capacitor is an CBB61 that’s rated for 2uF @ 450V. Could the 1.5uF reading be the culprit, or does this not matter as much? Should the fan still come on even if the 2uF cap is at 1.5uF now?
Another culprit I saw was that it could be the fan switches themselves. Not sure if this is relevant, but if I push any of the 1-3 switches on the fan when it’s disconnected from power, I get an “0L” reading in Ohms mode when I probe both the “L” and “N” prongs on the plug itself.
I have another floor fan that’s similar (not the same brand, but it’s the same type of floor fan). This one is working. When I run the same test with the switches, I get an Ohms reading when probing the N and L prongs on the plug. That tells me I should be seeing readings on the other fan when one of the switches is pushed down? Not sure.
Anyone got any idea of what else I can try? I’m not really fussed about fixing it (probably won’t be worth it), I just want to know what the fault is.
Update (01/06/2022)
It looks like it was just the thermal fuse that burnt out and blew. It looks a little charred, so must’ve got incredibly hot quite quickly. The cause is strongly likely to be the debris/hair that was on the shaft that the fan blade connected to. It had so much hair wrapped around it I couldn’t believe it. It probably couldn’t cool down because of this.
For now, the fuse has been bypassed. Yes, I know this is not recommended. However, I just wanted to see if the fan came to life with the fuse removed from the circuit. It works on all speeds perfectly fine for now. I will look on eBay to see if there’s a replacement fuse I can buy.
4 Comments:
If its still under warranty, check warranty details for replacement. If out of warranty, you may be beating a dead horse. In this case a dead fan. If dirt accumulated to block free airflow to cool the motor, this may accelerate its demise, possibly overheating. Sometimes on small appliances, a thermal fuse is inline inside the motor and blows. Most are small aluminum cylindrical devices with a black or red end, a little larger than small resistors. Thermal fuses conduct electricity with little resistance but opens to prevent electrical flow when overheated. Replaced with an equivalent rated replacement from electronic distributors.
by
@notbroken
Yeah, I figured it might be pointless trying to fix it. I just wanted to know what exactly has caused it to stop accepting power. This is mainly for my own knowledge. Trying to diagnose and fix things is a hobby of mine.
I unfortunately cannot get to the motor itself since the housing has a badly-stripped screw. I cannot remove it. I wanted to open it up and inspect. Are there any tools you can buy that can remove stripped screws on fans? The screw is quite big and completely stripped.
by
Drilling out the screw head can help whether its a machine or sheet metal screw.
by
@notbroken
Bought the Engineer pz-59 pliers from Amazon after seeing some videos of them successfully removing badly damaged screws. Got it out without much fuss using those.
Turns out the thermal fuse tripped after all. Fan works fine with the fuse removed, so I'll just need to look on eBay for a similarly-rated fuse.
by
Add a comment
1 Answer
You did not get readings on the multimeter because of the burned fuse… (the 1.5uF capacitance does not matter so much). Good you have found the problem! :)
Add a comment
Add your answer
vCore will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 999
