A Panasonic digital camera released in September 2013. The camera features 60x optical zoom and HD video and sound.
17 Questions View all
Flash does not light up
I have a FZ72 (which is very similar to FZ70).
The flash does not work. If I open it, the camera recognises it and also preloads the flash. But if I press the button to take a photo, the picture is taken and no flash lights up.
I assume the cables could be broken, because for some time the flash only worked, if I pulled the case of it a bit backwards.
My question is, what is the tiny blue device behind the flashlight. Also there are 4 cables altogether. Which could be broken? Is it possible to fix it at all?
Add a comment
1 Answer
Most Helpful Answer
Hi @hilfs08,
Check the capacitor and the connections to the capacitor are OK. This component provides the power for the flash to operate.
Score 1
1 Comment:
Unfortunately this did not help. The cables to the flash are covered on the flash-side by rubber, so you cannot measure anything. However I tried to discharge the capacitor and it recharged after turning on, but still no flash. :/
I assume the cable is broken somewhere, but since it is tightly attached to the light itself, I would have to find a new set somewhere...
by
Add a comment
Add your answer
Phil will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 21
All Time: 277
