Repair and service information for the LG TrueSteam clothes dryer. Model numbers DLEX3570V, WM3670HRA, and DLEX3570W for graphite, red, and white colors respectively.
5 Questions View all
Loud Noise, rumbling, low pitch when spinning the drum
My dryer makes a very loud rumbling noise when the drum spins. It’s a low pitch rumble (not the high pitch squealing that I have heard with prior dryer). It still dries the clothes and functions properly, but it’s just very loud, almost as if there was a heavy object spinning and bouncing with the drum (there’s only clothes). How can I fix it?
2 Comments
Hi @mbialas ,
What is the model number of the dryer?
Does the drum rotate evenly and smoothly when you turn it by hand?
by
Model # DLE8377NM
The drum rotates evenly but I had to use a bit more force than I recall in the past to move it. It does not skip, catch or shake but it feels like it's on rollers that are making the rumbling noise, almost like a rough vibration.
by
Add a comment
Chosen Solution
Hi @mbialas ,
It may be a faulty roller assembly. (supplier example only to show location, how to replace and the possible cost for each one)
There are 2 roller assemblies part #K250 & K251 and it is suggested if one is faulty to replace both. Search online for 4581EL2002H to find suppliers that suit you best.
Score 1
1 Comment:
Thank you so much. That makes sense that it may be the rollers. Thank you!!!
by
Add a comment
Most Helpful Answer
You have probably fixed this by now but here’s the best video, with precise steps, to replace the rollers.
https://youtu.be/VhfAA25JhFU?feature=sha...
Score 2
2 Comments:
Yes we fixed it. But thank you for your advice. It maybe helpful for another person who has the same problem
by
yes it will as soon as i get new rollers.
ifixit rocks man this website is awesone
by
Add a comment
Add your answer
Margaret B will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 36
All Time: 528
