Released in 2009, this device has a 4 digit back-lit digital display, AM/FM radio and a CD player.
I've got no power
NS-B4111 insignia won’t turn on
1 Comment
Are you trying to use the device with the AC adapter, or are you powering the device using the battery's.
by
Add a comment
1 Answer
Most Helpful Answer
This could be something as simple as a bad power cord. Checking with a DVM will confirm or rule it out.
Anything else will require disassembly and there are no service manuals available to help.
If you can figure out how to open it up, the next simple fix would be a fuse. Again it is an eyeball thing and a DVM verify. If it is a fuse, it might be just that or more likely something else caused it to blow. The next item is the power switch. Again, verify with DVM. Past that you need to be a little more technical to figure this out, or have someone put their hands and eyeballs on it. At $39.99 new, it will cost more to get it fixed. A new one will have some warranty. A fix won’t.
Score 1
Add a comment
Add your answer
ralph elliott will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 174
