Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
Does the iMac 7,1 (EMC 2133) support 800 MHz RAM?
I’m planning to upgrade my recently restored iMac and would like to know if I could use 800 MHz sticks or if I’m stuck with 667. Also, I’ve heard that this machine can go beyond its 4gb limit to 6gb. Is this true?
Add a comment
1 Answer
Chosen Solution
You won’t get any better performance as the systems I/O is clocked based. The CAS and RAS timing can be too short causing errors when using too fast RAM. And yes while Apple only lists 4 MB you can go upto 6 MB using one 2 GB SO-DIMM and one 4 GB SO-DIMM and the speeds need to match!
I would stick to the spec’ed RAM.
1 Comment:
Ok, thanks. I'll keep that in mind.
by
Add a comment
Add your answer
Zachary Rushworth will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 106
