Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
About this Mac says the CPU is 400 MHz.
Here’s me asking yet another question about this obsolete piece of history-
I performed a CPU upgrade from the stock C2D T7300 to a T9300 so I could use the Dosdude1 patcher. There’s a slight problem though- the CPU reports as 400 MHz in “About this Mac”. Is this fixable?
Add a comment
Chosen Solution
I’m going to guess that the CPU is actually running at the correct clock frequency, but since MacOS doesn’t recognize it (this wasn’t a CPU that was offered with this computer), the speed is being reported incorrectly. I’d recommend installing a third-party tool like MacCPUID and trusting what that reports.
Here’s an old answer post with some info about putting a T9300 in one of these older iMacs, there may be some useful info buried in there.
Score 1
3 Comments:
Haven't tried that tool yet, but it reports as the stock 2.5 GHz from the command line.
by
@shrek420 what Dan mentioned in his answer here still may be a valid concern. Your Mac might not be able to supply this CPU with the correct microcode, which could actually hurt performance. I'd recommend running a benchmark (like GeekBench) with the old CPU and the T9300 to make sure that you're actually getting a real performance improvement.
by
I really only upgraded so I could run Dosdude1's High Sierra patcher, not really for performance. Last time I tried messing with the CPU, I couldn't turn the machine back on for months. I don't want to mess with that again.
by
Add a comment
So lets look at the spec sheets to see what’s happening here:
So the CPU’s micro code held within the systems EFI (BIOS) is not able to support the Penryn logic. Clearly the Penryn 410 million Processing Die Transistors is a lot more than the Merom 291 million!
The best CPU you can go with in this series is Core 2 Duo Processor T7700 (4M Cache, 2.40 GHz, 800 MHz FSB)
Basically, you need to lookup what the series had referencing EveryMac to lookup the given system. Here this system is part of this series: iMac7,1
Add a comment
Add your answer
Zachary Rushworth will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 272
