{A1989 / EMC3214}—Released in July 2018, the 13" MacBook Pro features quad-core i5 and i7 processors and Intel Iris Plus integrated graphics.
208 Questions View all
thin horizontal lines on screen
When you turn on the laptop, a thin horizontal black line appears that occupies the entire screen. Curiously, they are removed by lowering the screen and leaving it approximately 5 fingers.
Update (01/16/2022)
Score 1
4 Comments:
Can you post some pics and a short vid so we can get an idea what you mean by five fingers. Adding images to an existing question
by
Even I’m facing the same problem..
by
how did you solve the problem? I have it too
by
@stardobaba - If moving the display alters the condition that points to a bad connection between the T-CON board and the LCD panel. This sadly requires a new display assembly.
A common cause is getting something caught between the uppercase and the display along the back edge like a paper clip or pen this in turn cracks the chin plate which covers the cables. As the space is so little the glass shards of the chin plate cuts the ribbon cables. Some clip on case covers can also do this too.
by
Add a comment
1 Answer
Ouch! I’m suspecting the ribbon cable connection to the LCD has become damaged. So its making and breaking contact.
Sadly, this requires a new display assembly MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assembly
And here’s the guide MacBook Pro 13" Touch Bar 2018 Screen Replacement
MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assembly Image
Product
$479.99
Add a comment
Add your answer
inoval will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 581
