The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
81 Questions View all
Im at a dead end and really need help
My 02 ram 1500 5.9l gas died as i was driving yesterday . I have fuel pressure and the coil has spark going to distributor. It turns over and sounds normal cranking but wont start. Recently ive replaced the fuel pump and coil along with distributor wires and rotor all have under 600. Any suggestions ?
Add a comment
1 Answer
Most Helpful Answer
Hi @dirtyboot,
Check the OBDII codes. There may be a problem with the camshaft position sensor (P0340 code) or the crankshaft position sensor (P0335 code)
If it is the camshaft sensor, here’s information from the service manual that may help.
(click on images to enlarge)
Score 1
Add a comment
Add your answer
BrandonV will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 90
