Dell XPS 15 7590, released in 2019.
6 Questions View all
How to reduce the fan noise
The fan seems to have got very loud and annoying. Do I need to switch it out? It was fine for a year.
Add a comment
1 Answer
Most Helpful Answer
First thing is to clean fan and surrounding area. Canned air is good to do this so you don’t actually touch anything inside. A dirty fan could limit its cooling ability and result in it working hard to cool things down. Make sure any air vents , also, are free of dust. Here’s the service manual:
Dell XPS 15 7590
You may also have corrupted system files.
Run the System File Checker (SFC) in Windows 11/10/8/7.
Type cmd in the Start search box. In the result, which appears, right-click on cmd and select Run As Administrator.
In the command prompt window which opens, type the following
sfc /scannow
and hit the Enter key. Let it run and do its job.
Score 2
4 Comments:
Thanks. I don't think this is to do with heat. It started when it went from Windows 10 to 11. The fan is running even when the unit isn't particularly hot.
by
@wrights
Hi Simon, I've edited the Answer above.
by
Unfortunately, it didn't find any integrity violations.
by
@wrights
Any idea what is running in the backgrpound?
Have you checked temperature of CPU?
by
Add a comment
Add your answer
Simon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 33
All Time: 2,210
