The fourth-generation Surface Pro tablet, released October 26th, 2015.
210 Questions View all
Surface Pro 4: New Battery, powers+charges only while plugged in
I installed a new battery in my Surface Pro 4 (didn’t see an option for that device). I plugged it in, powered on smooth, and charged up to 100% to begin calibrating. Once I unplugged it to continue calibrating, it goes immediately black and I have to plug it back in to reboot. I’m certain everything plugged in correctly, I followed the video closely. To my understanding, the battery “tab” just slips under the board and sits underneath the tabs to connect. Am I correct in thinking this, or have I made a dire mistake?
Taskbar icon has a plug and a full bar (didn’t start out full when I first started up), so it is recognized and taking a charge. Battery diagnostics recognize a battery is connected. Is it possible the battery could be defective? Or do I need to crack it open again and check on something I may have overlooked.
Score 1
2 Comments
Hi,
Don't know the laptop, but looking at Step.48 of the ifixit Microsoft Surface Pro 4 Battery Replacement guide, it shows that the battery connector is glued down to the case. Maybe a loose connection if you didn't glue it back down.
Just a thought.
by
I did, it has an adhesive section that I slid under the connection to the board.
by
Add a comment
1 Answer
Most Helpful Answer
Hey, I think the problem in this thread looks similar to yours!
After replacing sr pro 4 LCD,won't turn on battery mode unless plug it
Score 1
Add a comment
Add your answer
Mitchell Nuyens will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 148
