The Lenovo G50-80 is an entry level personal laptop released by Lenovo in 2009. The laptop has a 15.6 in screen and uses an Intel GPU processor.
16 Questions View all
which Size(mm) using in Caddy 9.0mm or 9.5 Size.
It is possible ,I am Upgrading HDD & SDD IN Lenovo G50-80 LAPTOP l am HDD using Caddy .it Working or Not .If it is working which Size(mm) using in Caddy 9.0mm or 9.5 Size. Thank you.
Add a comment
1 Answer
Most Helpful Answer
Hi,
If you are replacing the HDD in the laptop with a 2.5” 7mm sata SSD you will need a 7mm to 9.5mm adapter (supplier example only) to sit under the SSD so that it aligns correctly with the port connector.
Here’s the ifixit Lenovo G50-80 80E5 Hard Drive Replacement guide that may help.
Score 1
Add a comment
Add your answer
Ajith Kumar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 891
