Released September 20, Apple's mainstream 2019 iPhone comes with a 6.1" LCD touchscreen, dual cameras, and six available colors. Successor to the iPhone XR.
iPhone 11 Screen Repair Question
I have been researching what I takes to repair my phone. I signed up for IFixit and looking at some tools to buy.  All the content looks great!
Quick question, what is the different between replacing just the clear portion of the screen of a phone and replacing the “screen” as you have it listed on IFixit website and in the videos.
Amazon, for example has kits on repairs that are less expensive but it only looks like they are replacing the actual clear portion of the screen. https://www.amazon.com/Replacement-Compa...
I don’t understand the difference.
Thanks in advance
Add a comment
Chosen Solution
It's far simpler to replace the full LCD/Glass/Frame assembly. Even majority of repair techs will change like this.
To change the top glass, is called refurbishing, and this requires more specialised equipment, so for someone who does the odd repair, this isn't cost effective at all. So it's best to keep these working displays, and sell to a refurbishing company (I'll gladly buy them if in the UK)
To replace the top layer of glass, you'll need all the tools which you already know of for a replacement, plus the following:
Frame seperating tool - Different types, but most effective is a high temp heat plate designed to push the frame into it and soften the glue on the frame.
Vacuum heat plate - Holds the LCD down and heats the LCD so you can cut the glass off.
Various other bits like blades/chemicals/wipes/sponges.
Then you (ideally) need a mould for LCD/glass alignment.
A laminator (basic is around £450 and a decent one up from £1000)
Then a debubbler to remove any bubbles created from the lamination process. (You can get some of these machines which do the two together)
And the last bit, you'll need quite a few displays to practice on, because I can guarantee, when you first do one, it'll break.
Plaves like replacebase/iparts 4 u sell just the glass, bit it's really not suitable if you don't have the equipment.
Replace the full assembly, and sell the working display (if you get it off nicely)
Here's a video I've done for an XR glass/touch replacement. Should become clear what's involved then. https://youtu.be/tlng-9ONOP4
Definitely worth investing in if you are repairing alot of devices, your margins are considerably increased….. once you've nailed it.
Hope that helps you understand it a bit better 😁
Score 1
2 Comments:
This was great. One follow up question, if I buy a full LCD/Glass/Frame assembly and replace it is it considered a refurbishment? Thanks
by
You could class the repair as refurbished with the full replacement of a complete LCD replacement, but not able to say OEM parts etc. 👍
by
Add a comment
Most Helpful Answer
Replacing the “clear portion” is generally just replacing the top layer of the display. Essentially on most phones, this is just protective glass, which is why it is less expensive because it does not contain portions that are necessary for the function of the screen. It’s just glass.
If that is the only component of the screen that’s damaged (so it just looks like cracked glass on top of a fully functional display and touch function is totally intact), it’s definitely doable. And WAY less expensive in many cases. However. It is a much harder repair to do without introducing additional damage to the display. Because this layer is adhered with very strong adhesive, it can be tedious and difficult to remove without hurting the underlying display components. It’s not something I would generally recommend for a repair novice.
Score 2
1 Comment:
OK, I understand. I assume that explanation is why ifixit doesn't sell just the just the glass (as far as you know)? Thanks for the response!
by
Add a comment
Add your answer
Derek Skipper will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 363
