The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
152 Questions View all
Necessary Components for Screen Replacement
Hi,
I’m confused about which components I need to replace my iPad 6th Gen screen.
I think I have it right but I’m not sure. I have in my cart the following:
***iPad Air, iPad 5, iPad 6 Adhesive Strips***
***iPad 5/6/Air 2/mini 4 Home Button Gasket***
***iPad 5/6 LCD***
***iPad 6 Screen Digitizer***
I already have the Essential Electronics Toolkit, which I think is up to the task.
Many thanks in advance
iPad Air, iPad 5, iPad 6 Adhesive Strips Image
Product
$6.99
Essential Electronics Toolkit Image
Product
$29.95
iPad 5/6/Air 2/mini 4 Home Button Gasket Image
Product
$6.99
iPad 5/6 LCD Image
Product
iPad 5/6 LCD
$109.99
iPad 6 Screen Digitizer Image
Product
$44.99
Score 1
Add a comment
1 Answer
Chosen Solution
Hi @rogercorbett,
Take a look at the guide to replace the front panel assembly and check out the Parts and Tools sections to see what you'll need. (Steps 1-40 will instruct you on how to remove the LCD and when you keep following you'll remove the digitizer, as well.)
As far as I can tell you seem pretty set with that list! My only suggestion to add would be an iOpener to help soften the current adhesives and a battery blocker (or you can make one using a playing card!)
Good luck with your repair!
iOpener Image
Product
iOpener
$19.99
Battery Blocker Image
Product
Battery Blocker
$3.99
iPad 6 Wi-Fi Front Panel Assembly Image
Guide
iPad 6 Wi-Fi Front Panel Assembly Replacement
Difficulty:
Difficult
55 minutes - 2 hours
iPad Image
Guide
How to Disconnect an iPad Battery with a Playing Card
Difficulty:
Easy
5 - 10 minutes
Score 1
1 Comment:
Hi @amber thank you very for your advice. It’s all adding up so I think I’ll get the battery blocker and make do with a hair dryer.
by
Add a comment
Add your answer
Roger Corbett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 364
