Problem with battery charging
Good evening,
I've been changing the battery on my iPhone XS and unfortunately I've had an error. It's not my first iPhone I've repaired and I was stopped by this problem.
The thing is that when I want to charge the phone, I have to first turn it off, put it in the charger and turn it on, otherwise the phone won't start charging.
Do you know where the fault could be?
Thank you very much for your advice.
2 Comments
What did you repair on the phone or you just mean you need to repair the phone ?
What happens when you plug in the charger doing this without turning it off first?
by Alisha C
Well, I bought the phone from a friend of mine with the fact that he can't turn it on. I replaced the battery and it went on.
Only problem I found was that when I plugged the charger into the phone it wouldn't do anything. It's like it's not there. I have to turn it off, plug in the charger and turn it on. Then it works.
by Simon K
