2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Questions View all
How concerned should I be about these slightly swollen batteries?
Hi all,
I noticed a slight wobble in my MacBook when I set it down on my desk. I opened it up to check on the batteries and noticed a slight pressure on the backplate while I was unscrewing it, all but confirming my fears. And sure enough, as you can see in the picture my batteries are swollen; but only slightly. It’s slight enough that it’s hard to capture on camera without a light background, but if you look at the rubber pads you can see they are not level.
My question is: how concerned should I be about this level of swelling?
It’s not nearly as severe as the Google Image results for swollen batteries, but they are swollen enough to be noticeable and put pressure on the backplate. All batteries have a very slight bulge to them, the one in the picture is the most severe. I’ve powered the laptop off and unplugged it from the charger.
  • Am I being paranoid or am I right to be concerned? Is this an “acceptable level” of swelling, or should I immediately stop using the device?
  • Are the batteries in danger of catching fire at this stage? If so, what steps should I undertake to keep it safe?
  • Is it still safe to power it on briefly to backup any files that aren’t already backed up or should I leave it turned off?
Thanks for any help you can give me answering these questions.
Score 2
Add a comment
Chosen Solution
@robinabspoel
    • No you are not. There is no acceptable level. Remove and replace ASAP is the proper thing to do!
    • No they are not. For as long as they have room to expand, venting with flame is unlikely. Remove those batteries and dispose of them properly at an authorized recycling center.
    • Briefly to make backups of your stuff will be okay.
Hope this helps.
Score 3
1 Comment:
Some extra tips:
When removing the battery adhesive, do not use heat. Instead, use Isopropyl (Rubbing) Alcohol or a similar solvent in conjunction with plastic cards/opening picks.
Do not change the batteries if you can help it. Batteries are easier to deal with safely when more discharged.
by
Add a comment
Are they mushy like jello? Then yes.
Add a comment
Add your answer
Robin Abspoel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 125
