The sixth generation of the Subaru Legacy made its debut at the 2014 Chicago Auto Show, and went into production for the 2015 model year.
2 Questions View all
check engine light on code p700.
i got this check engine light everytime it rains . i scan the code and it show p700 . ( transmission failure ) however the car run okay no problem and after 2 days of doing running the check engine light will turn off.
1 Comment
See if the diagram here helps. It's from the Outback Owners site.
https://www.suoutback.com/transmission_h...
by
Add a comment
1 Answer
Chosen Solution
It could be a number of issues but when you said it mainly happens when it rains then i would put money on it being a bad connection in the wiring harness to the transmission. Maybe water causing a short circuit & then once it’s dried out the transmission control unit thinks the fault has cleared.
I would follow the wiring harness from the left side of the dash, through to the gearbox. Checking for any breaks in insulation & also the security of any connector blocks outside of the interior of the vehicle. I know the Subaru Forester has 2 BIG connector blocks on the top of the gearbox around the bell housing area. It maybe the problem lies in those. Google your transmission wiring harness & see what the photos show you.
Good luck
Score 1
Add a comment
Add your answer
EDWIN CHAN MENCIAS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 335
