The third revision of the classic Xbox Wireless Controller was released in November 2020, bundled with the Xbox Series X and Series S. This controller is backwards compatible with previous Xbox One consoles, and PCs.
42 Questions View all
Where can I find/buy replacement trigger contact pads?
My trigger was sticking for 1 second after I released it so I removed the casing and wiped clean the contact pad (tiny rectangular material that absorbs the trigger press to prevent tapping/clicking sound) with rubbing alcohol, but lost that piece. Where can I find a replacement for the pad? And am I even using the correct term?
Score 2
1 Comment:
I have the same problem. Except I didn't lose mine, it fell apart as I was trying to remove it to try and realign it.
by
Add a comment
1 Answer
M'y fix was to use adhesive velcro ( soft side like the fluffy side ) in place, it works great
Add a comment
Add your answer
Blake will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 49
All Time: 1,987
