Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
How to fix stuck bootlooping
how to fix iPhone 6 s plus boot looping I have this iPhone 6s plus that has a good battery and is stuck boot looping I was using it and it just froze and then I turned it off and then once I did this it just rebooted and now has been like this for a couple of hrs how do I fix this problem also the phone does this when unpluged
Score 1
Add a comment
1 Answer
Most Helpful Answer
Put the phone into recovery mode and do an update with iTunes or 3uTools. Let us know if you receive an error.
Score 1
9 Comments:
i tried to put the phone i recovery mode by pressing and holding the home button and off button but it just shut off and then when i let go it still just went back on am i doing it right?
by
@keith_themuscovyduck Keep holding the home button and power button, the phone will eventually shut down and restart keep holding the buttons until recovery mode. If it will not go into recovery mode you could try DFU mode but you might have to do a restore instead of update.
by
ok thanks i got it in recovery mode
by
@imicrosoldering
i updated and its still bootlooping
by
@keith_themuscovyduck If it updated without any errors you will need to rule out a parts issue. Replace the battery first.
by
Show 4 more comments
Add a comment
Add your answer
keith_themuscovyduck will be eternally grateful.
Past 24 Hours: 12
Past 7 Days: 12
Past 30 Days: 24
All Time: 222
