Acer Aspire 3 A315-21-92FX is a series of with budget computers designed and sold by Acer. It is one of the cheapest computers in the market. The camera is equipped with 720 pixels HD webcam.
17 Questions View all
white screen, works when plugged in to monitor via HDMI
so i've has this laptop and issue for a while, it started as some dead pixels on the corner of my screen and slowly spread outwards until the entire screen turns white upon boot. i recently decided to power the laptop on again and using an hdmi cord to plug it in to a TV which worked perfectly
Add a comment
1 Answer
Chosen Solution
When you start getting dead pixels like that spreading over the screen, it's the display that is broken. Since the rest of the computer works, you will have no problem at all using the computer itself.
Solution 1 - New Display
The first solution and the one I think is the best is to replace the screen with a working one, I can't really recommend a specific replacement for you but it should be possible to find one.
Solution 2 - Use External Display
If you aren't planning to use it as a laptop and taking it with you to different places, instead most use it at home or a specific place. I wouldn't say there is any reason to replace the screen since you could just use an external monitor.
Score 2
Add a comment
Add your answer
Ian Maguire will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 764
