Repair guides and troubleshooting for Acer Predator 17.3" laptops, a group of high-end gaming computers from Acer. These laptops features a 17.3" display, dedicated GPU, and a modular bay for either an optical drive or cooling module.
16 Questions View all
Battery not taking a charge?
My acer predator laptop all of a sudden stopped charging, one night it was charging just fine and the next day it just stopped, it wasnt moved from its spot or dropped or damaged in anyway, just stopped charging
Score 2
3 Comments
Try taking out the battery and starting it
by
Hi @ josh price,
What is the model number of the laptop as printed on the label on the bottom of the laptop?
Have you tried a different compatible charger to see if that worked in case the charger or charger cord is faulty?
by
@jayeff im about to order a new charging cable, will update when it arrives
by
Add a comment
1 Answer
Chosen Solution
I will suggest checking the charging cable first, if there is a charging light indicating on your laptop and still doesn't get charged then under the laptop you will find a small battery reset buttonhole, using any pin you can reset the battery. Hope this will solve the problem.
Add a comment
Add your answer
josh price will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 45
All Time: 1,393
