Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
435 Questions View all
iMac 2007 24 inch changeable with the 20 inch?
Hi all,
So I have a dead iMac from 2007 (24 inches) and I'm getting a 20 inch one for free. Of course, the 24 inch screen is nicer, so can I put the 20 inch computer inside the 24 inch case and use the screen from the 24 inch?
Thanks in advance
2 Comments
Depending on the exact 20" model you might be in luck.
by
It's a 2007 model as well.
by
Add a comment
Most Helpful Answer
As you can see here the logic boards are very similar!
iMac Intel 24" EMC 2134 Logic Board
iMac Intel 20" EMC 2210 Logic Board
The layout is the same, I'm suspecting its doable. I personally haven't done it but it would be a fun exercise to try!
iMac Intel 20" EMC 2210 Logic Board Image
Product
$44.99
iMac Intel 24" EMC 2134 Logic Board Image
Product
$34.99
Score 1
8 Comments:
@danj which power supply would I use? Or would I use both? I'm assuming that the 20 inch power supply is less than the 24, but not compatible? I'm sure there would be lots of space either way
by
@gaussymousy - You're just swapping the logic board correct? Thats all you should need to do.
by
@danj Yes but I still need a power supply right? Not sure if I can use the 24 inch imac's power supply in my 20 inch board.
by
@gaussymousy - I'm not sure I'm following you here. The 24" iMac power supply can be used.
by
@danj Ok so i've decided not to do the swap, but after I opened the 20 inch iMac, the cpu fan now goes on full blast. I've done all the resets, and checked the cables (Though for some reason if I power it up while the bezel is off, no fans) The fan goes to full about halfway through the apple logo. No fan control software is installed.
by
Show 3 more comments
Add a comment
First you need to discern why the 24" is not working. Probably the power supply. Take a look at the diagnostic LEDs on the logic board and tell us what you see.
2 Comments:
@mayer The optical drive makes the startup sound, but there are no other indications of life. As far as the LEDs go, the first three are on, but the last is not.
by
The 3 LED lights shows power supply and logic board are good. On this model your most likely failure is the video inverter.
by
Add a comment
Add your answer
Gaussy Mousy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 152
