Apple's seventh-generation smartwatch, with optional cellular connectivity, released October 15, 2021.
15 Questions View all
Speaker sound distorted and muffled
Speaker sound distorted and muffled with high pitch tone after dunking in sea water at seaside and micro scratches appears on the top of the screen, please help me repair it
Add a comment
1 Answer
If your watch has no damage, get a bowl of warm distilled water (not tap or spring!) carefully take off the straps and place the watch into the water. Let it sit for a few minutes and pull it out press the water drop from the control center then rotate the crown to enable the cleaning cycle which will engage the speaker. You may need to do this a few times to get the junk moved out.
Reference: How to use Water Lock and eject water from your Apple Watch
Add a comment
Add your answer
Sohaib Alam Khan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 5,580
