The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
43 Questions View all
Left stick drift and delayed response time
The left stick is always drifting. Sometimes it's not noticeable in game but in menu it will cycle up consistently. Sometimes a quick flick fixes it. Other issue is you press the stick in and the action is not always crisp, there is a delay
Score 1
Add a comment
Most Helpful Answer
connect the controller to a pc or laptop then open this site, https://gamepad-tester.com/. it will show you how bad its moving. if bad it needs the analogue stick replaced.
Score 2
Add a comment
Hey Tyrone! I was able to fix it by opening up my controller and cleaning the sensors on the left stick. This helped me a ton.
When you get to step 11, make sure you move both the green plastic housing for the left stick's sensors. The one on the right controls the X axis and the one on the bottom controls the Y axis. You most likely need to clean out the bottom sensor with some canned air and it should work.
Saved me a few hundred bucks by not buying another controller! Hope this helps out!
How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller
Score 1
Add a comment
i replaced the analog stick but the problem persisted. i think it might have something to do with a capacitor
Add a comment
Add your answer
Tyrone Palmer will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 114
All Time: 3,056
