I can’t remove screws from home button
I’m having trouble removing the home button screws, I’ve tried two different screwdrivers and they’re not budging. please help
Two two screws are just Philips #000. Assuming you're using the correct screwdriver and you haven't stripped the screws, a good way to get a tight screw loosened is to actually tighten it a tiny bit first. This "breaks" the seal that the screw may have with its matching thread, making it much easier to loosen and back ou.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 48
