Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
116 Questions View all
I have an unreliable thunderbolt port, the second one works fine,
What could be the issue? The first one works then stops, then works then stops, I noticed some corrosion on the board while replacing the trackpad, but it's very confusing. None of them seem to even affect the tb3 controller.
Score 1
2 Comments
How about posting some pics so we too can see the corrosion Adding images to an existing question
by
I wiped away the corrosion and it works fine now, haha! Quite interesting, there was corrosion shorting one of the very small chips on the board, almost looks like a tiny mosfet.
by
Add a comment
1 Answer
Chosen Solution
You may need to replace the MacBook Pro (A1989, A1990, A2141, A2159, A2251, A2289, A2338 Mid 2018-2022) USB-C Board that will require lifting the logic board out to give you access to the screws which hold the port assembly as you can see here
MacBook Pro (A1989, A1990, A2141, A2159, A2251, A2289, A2338 Mid 2018-2022) USB-C Board Image
Product
$14.99
Score 1
1 Comment:
Wiped away the corrosion and it works now, but Dan's answer is the one that should work for basically everyone. <3 It seems like my problem was on the main board though, not the USB port board!
by
Add a comment
Add your answer
wkw030210 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 19
All Time: 316
