Why my phone is slow changing
Why my charging taking lot of time
Score 6
1 Comment
Very slow charging problem and very slow working mobile system
by
Add a comment
Most Helpful Answer
Battery could be going bad, you could be using a charger that does not support fast charge. If fast charge is not available in your settings that would be likely.
Score 2
1 Comment:
when i have time to reply🤣🤣
by
Add a comment
The problem can be caused by using cheap cable or adapter, make sure you have right charger(fast charger 15w), if you are using different adapter that is below 15w will charge your phone slow if its above 15w it will damage you battery.
Score 2
Add a comment
Add your answer
Bag pack Gamer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 891
