The Dell Inspiron 17R-N7110 is a 17.3-inch laptop with an Intel Core i3 or i5 processor.
7 Questions View all
Can I replace the HDD with an SSD for the Dell Inspiron 17R-N7110?
I've had this laptop for longer than I can remember. I found it and got it fully factory new. The specs are not bad (i7 and 8gbs RAM).
However, my fans are always going crazy and speed is consistently slow, even with a clean Windows install. I checked Task Manager and found that the HDD (Disk) is always at near 100% whenever I do anything. The only times where the PC is fine is when a task is being run without changing it's state. (ie staying in one webpage, not forking any new processes.) However, if I start anything or change state, then the throttle comes in.
I suspect that the HDD is bottle-necking the performance of the computer and would like to know if there is a way of improving the hardware. I want to know if we can avoid the bottleneck or if its not worth the time/effort.
Score 1
Add a comment
1 Answer
Chosen Solution
Strange you should ask,. It happens that what you need to do that is here. Happy upgrading. (I'd do a virus scan if the system is constantly working, and I'd do a teardown and clean everything if it's struggling to cool itself, fans heatsinks, etc. After "forever" you might also want to reapply thermal paste as appropriate.) I expect you will enjoy a very noticeable improvement, In my humble opinion it's definitely worth doing. I would also take a look at task manager and see what processes are responsible for all that activity, but me, I'm paranoid.
Score 3
4 Comments:
Thank you! I'm definitely gonna go ahead and disassemble it.
As a side note, I also wanted to express my appreciation for your kindness. Many of these types of forums quickly get toxic/condescending. I appreciate your knowledgeable yet compassionate comment.
by
Thank you from all of us! It's nice to get feedback, I've done this on a number of old devices and on my own as well, it's a good performance boost.
by
I done it but my lag issue is not resolved 😕 pls help is there anything to do after it??!
by
If switching to an SSD didn't give you a very noticeable speed and performance upgrade I scan for viruses & rootkits. Look at running tasks in task manager, identify processes using your CPU time and Memory. If you find a program or service are hogging resources consider uninstalling of disabling them. BEFORE disabling or uninstalling any software or service be sure to duckduckgo any you don't KNOW is something you don't want/need. Remove any junkware that you might have installed or may have been installed along with other software (like browser toolbars and similar "freeware" that slows and steal resources, if you don't use or need it, get rid of it) The free cleaner tools might be helpful in finding and removing bloat but doing it yourself keeps THAT from being additional bloat... or just uninstall it after you've cleaned things up. Increasing memory (if possible) might help but I wouldn't expect a noticeable difference in most use situations 8 GB is "good enough" for most users up to now.
good luck
by
Add a comment
Add your answer
Lango will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 20
All Time: 489
