Released September 20, Apple's largest and most expensive 2019 smartphone features a 6.5" OLED display, a triple-lens camera system, and greatly improved battery life. Successor to the iPhone XS Max.
166 Questions View all
Low volume button not working, button and cable has been replaced.
Button and cable has been replaced but volume wont go down when you press the button. It goes up and you can manually scroll down in the screen but not with the button.
Add a comment
1 Answer
Most Helpful Answer
Hi
Have you tried cleaning the connector’s on both the cable and the board as iv had issue where new parts don’t work but once I cleaned they with iso (isopropyl alcohol)they work again normally
if this doesn’t work make sure all the pins look nice and shiny and not black or burned/damaged
Hopefully this helps ,however if it doesn’t please don’t hesitate to give me a shout
Score 1
Add a comment
Add your answer
Jimmy Vega will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 84
