Maximum RAM over 12 GB?
I have an Acer Aspire 3 A315-21-95LK (Part Number: NX.GNVET.046). According to the official datasheet the maximum memory supported is 12 GB (4 GB onboard + 8 GB in slot), has anyone tried to install more than that? Did it work?
Score 1
Add a comment
Most Helpful Answer
@dinoo_fixit people have upgraded with 16GB module (supported). So you would end up with 20GB total RAM. Anything above that may not be supported by the BIOS.
Score 3
10 Comments:
Officially the 16 GB module is not supported, but as it looks as someone succeeded, I'll try
by
@dinoo_fixit I would not be one bit surprised if it will work for you. Let us know what you experience.
by
Did computers run faster after memory upgrade?
by
@jr1958 it will not have a large impact on the computers speed.
by
@oldturkey03 It's based on the CPU with 2x+ SODIMM or soldered+SODIMM config these days so not new. This is why I shun anything partially soldered; you can squeeze 32GB out of them because the machine isn't hampered.
This is why I write off machines like the Lenovo "s" series too; they're either fully soldered now, or partially. Add a 1/2" to the laptop and put dual slots in. Lenovo/HP/Dell may not admit this is why they partially solder the RAM, but this is **WHY** -- they're trying to stop us from loading "16GB" laptops with 32GB.
by
Show 5 more comments
Add a comment
How much memory does the Acer Aspire 3 A315-21 Laptop take?
You can upgrade your Acer Aspire 3 A315-21 Laptop to up to a maximum memory capacity of 12GB Memory.
How many total memory slots to install memory?
The Laptop has 2 Slots ("1 Upgradable") to install memory, already with 4GB (Soldered) standard memory installed. For best Aspire 3 A315-21 Laptop performance use the maximum amount of 12GB, fill all the slots with the max allowed memory per slot for your Laptop.
Score -1
9 Comments:
I know that officially only 12GB are supported, but some laptops support more than officially stated, so I was asking if someone had tried to install more than 12 GB and in case what happened
by
nothing happens it's like me giving u a glass of water and u can only drink 1/4 the glass u still have 3/4 of it just cant use that 3/4 good for backup but not rated to be used Cuz Ur limited by the board
by
Can I put a more powerful CPU in a Acer a315-22-95kf?
by
Can I put a more powerful CPU in a HP 15-f010wm?
by
@jr1958 which one? Both?
by
Show 4 more comments
Add a comment
Add your answer
dinoo_fixit will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 2,681
