Why is it still painfully slow after upgrading to SSD?
I recently bought a MacMini2014 from eBay. The stock hard drive was clicking and it was really slow so I swapped it out with an upgraded SSD. (Crucial MX500 1TB 2.5" SATA).
I used online recovery to instal MacOS - so there was no data or partition information carried over from the old stock drive.
It takes about 25 seconds before I see the Apple logo - and then a further minute before it fully boots up.
I feel like I’m missing something obvious here but all my searches thus far haven’t yielded a solution.
Score 1
6 Comments
New ssds are not compatible with older machines, I'm not a mac user but I assume you checked that? I saw a post here recently on the topic. Might figure in. https://www.crucial.com/compatible-upgra...)
by
Hi,
Thanks for taking the time to comment.
I checked as far as the SATA version (my Mac is SATA 3).
I have done some research and tried a few things like enabling TRIM support etc but had little luck.
Currently trying recovery option I’ve erased everything and trying clean install.
Worryingly - the time has jumped UP by 15 mins.
by
Hang in there, I expect a Mac person will turn up shortly.
by
hi
sorry to here you are having a problem with your Mac
I'm quite good with Macs so I will try my best to fix your issue!
lets start by downloading this https://apps.apple.com/gb/app/blackmagic... from the App Store
if you can run it and tell me the speed for read and write and we can work from there
by
Hey,
Thanks for replying. I missed the email notification, so just reacting now.
I actually downloaded the app right after I re-installed the OS. From memory I was getting around 380mb/s and 430mb/s which felt Ok to me.
I tried resetting PRAM/NVRAM I got the double chime so I’m confident it was done right.
I’m starting to wonder if it’s just a case of the CPU isn’t great (2 core i5) and it’s trying to run the latest MacOS and struggling.
by
Show 1 more comment
Add a comment
1 Answer
Most Helpful Answer
Hi
From what your speed test result ad what you’ve already tried is telling me ,it sound like you have bad RAM
Not to worry though I would try reseating it and if no luck plug one stick in at a time and see if you can find out what one is bad through process of elimination
Hopefully this answers your question
If not, keep on going with the info!
Score 1
2 Comments:
Sadly, the RAM in this model is soldered in. Is there a comprehensive tool that can check CPU/RAM and give off a report that I could upload?
by
Sadly as far as I know there isnt a app but there is a a command
If you power down your Mac and then on your keyboard press command D when powering back up
It will boot into a apple diognostic and should tell you what the issue is
by
Add a comment
Add your answer
Wayne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 494
