Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
141 Questions View all
No drain filter? Absolutely NO clean out! SERIOUSLY Electrolux?
eflw317tiw2 Electrolux stackable unit. Washer.. I’ve searched and searched for months on and off but now.. it’s A SERIOUS PROBLEM. From everything I can get my hands on this model has absolutely no clean out/drain pump filter. I shake everything vigorously even lint brush before going in wash, every last thing is shaken til I’m exhausted putting a load in.. my washer has fur and hair and lint and who knows what that should have been able to go in the drain pump filter and be cleaned out circulating through EVERY LOAD. I’ve run clean machine more times than I can count with bleach, with washing machine cleaner with other random chemicals I’ve read might work. Only thing this did was loosen up more trapped in the GRIME that was holding it in place on the exterior of the tub. So without removing the deal I used the higher concentrate bleach and got EVERY LAST MILLIMETER of the vile door boot. I wedged my fingers in and sprayed bleach on the stainless tub as far as I could and also on the white plastic piece that is visible when you really pull back the ring without removing it. You get like about 1/2-3/4 separation for visibility behind/under* the rubber seal.
So please.. I’m actually quite MacGyver but this washer is a bottom of the food chain model. Help me!? I’m begging! Where do I go from here knowing physically I’m not strong enough to lift the dryer and dismantle this whole deal and give it a hard core scrubbing.
Perhaps there is a drain filter Electrolux does not want us to know about?
What about this slime sludge.. will it ever go away with like 20 clean machine cycles?
I Need to wash clothes but I don’t want to forever have to take sheets and towels to the laundromat cuz washer can’t handle any type of lint hair fur.
Currently the stupid thing LEAVES MORE ON MY CLOTHES THEN THEY WENT IN WITH. that’s just not ok. And not how washing machines are supposed to work. Especially washers that are used by ONE PERSON that does not use a lot of laundry in two years.
I’m disgusted, frustrated and at a loss…
}{eather
Btw.. i found ifixit during a moment situational blindness. Probably about 18 months ago. An amazing human basically solved what to me at the moment was catastrophic due to anxiety I didn’t realize what I’d done. I still remember that night and feeling like he was an actual Angel here on earth or had some magic appliance super powers. Crazy anxiety.. but still super thankful and grateful. Current proble,pm has been researched so many times and escalated over probably 9-12 months. Thanks for reading my ramblings., have a great day. :)
Score 3
3 Comments
I don't think this will address your problem but there IS a sump filter in this washer here is a video on replacement; not an easy job. Still looking but so far no joy.
by
My Luxcare washer has whats called a 'coin trap' filter basket inside the drain hose from the tub. Hope this helps.
by
The washer filter is located within the coin trap hose under the barrel. Remove two screws in back of unit. Then remove top. Remove screws on top to enable removing front panel. Locate coin hose under barrel at bottom of washer. Remove filter from hose and clean. Replace and close up the unit.
by
Add a comment
1 Answer
Most Helpful Answer
Okay, this is what I found! You can ADD a lint filter, Yay!. Go here to learn how. Added: I suspect a Macguyver like you can probably DIY it with just the idea out there, have fun! More informative link.
Score 2
4 Comments:
That's why I removed Electrolux washer from my shopping cart and bought an LG washer. On the Electrolux, you need to remove the top panel, the front panel by first tilting the washer backwards to access the screws. How many times can you do this before the screws and the holes get messed up. Really, a bad design so that the service technicians can make more money.
by
I have the luxcare. I spent the extra money to get a machine that would last a while. I had a clogged filter. I have taken it all apart, cleaned the filter, and I have been no less than a WEEK trying to put the front panel back on, I finally have it back on and the holes where the dispenser part goes back in will not line up. I am beyond fed up. Any advice on how to fix this? I am really at my wits end.
by
I have the luxcare. I spent the extra money to get a machine that would last a while. I had a clogged filter. I have taken it all apart, cleaned the filter, and I have been no less than a WEEK trying to put the front panel back on, I finally have it back on and the holes where the dispenser part goes back in will not line up. I am beyond fed up. Any advice on how to fix this? I am really at my wits end. UPDATE: I finally, through the grace of God, finally got it back on. I am disappointed that it should be so difficult to fix this filter issue. I had high hopes for an otherwise fabulous machine.
by
We have owned model elfw7537aw1 for about six moths. Owned the model pretty close to it the previous 12 years. With the old model never ever had a clogging issue. Had a bearing issue. Last night had a clogging issue. No way to access the pre pump filters with out first removing the top and front of the machine . Which I did not want to do. And I couldn't, because there was water in the tub and that door was not going to open. Catch-22, right? No access panel door to the pump. So I made my own. Got my 7 inch grinder out with a cuttuing blade and made myself about a 10 x 10 hole. I disconnected the circulating pump hose as it was in the way. I then disconnected the hose from the drum to the pump, disconecting the pump side. And drainrd the water into a bucket. After water all drained I removed the entire hole, reveling the pre pump filter which was clogged with pieces of the rug that was being washed at the time. Hopefully I will never need to unclogg this filter again.
by
Add a comment
Add your answer
Heather will be eternally grateful.
Past 24 Hours: 16
Past 7 Days: 128
Past 30 Days: 561
All Time: 16,378
