Can I swap Silver Display Assembly for the Space Gray
Can I swap display assemblies of different colors within the same model?
Over the years, I have replaced many a Macbook Pro/Air display assembly. Occasionally, this has meant using an alternate color when the desired color was unavailable (ie: replaced a space gray with a silver one).
I just did such a swap with the 2021 Macbook Pro 14-inch (a2442), after being unable to locate a silver one to match the original one that was damaged. Now, it won't start. I followed all the standard procedures during the servicing (ie: disconnect battery, drain excess power, careful while "under the hood").
Obviously, I'm going to try and charge up the Mac . . . as soon as I can get my hands on the right charger. Until then, I just wanted to make sure this display assembly swap should work.
Thanks for any input. Off to find a charger.
