The Marshall Kilburn Bluetooth speaker is a compact, portable stereo speaker. This speaker comes with a built in Class D amplifier with quality sound range for its size. Bluetooth connectivity also allows for quick connections to bluetooth capable devices.
21 Questions View all
Volume level low and does not change
Marshall Kilburn speaker volume is low, and the volume control knob does not change the volume in any way. Bluetooth and line in is all the same. I have tried this on three different devices and they are all the same.
Score 2
Add a comment
1 Answer
Most Helpful Answer
Hi
from what your question has told me it sounds like time for a new battery in your speaker!
im not quite sure how to replace it on this model but im pretty sure that YouTube will have a tutorial and eBay will have a battery for you
if you need any help along the way I can try my best to assist you!
Score 1
2 Comments:
I may have forgotten to say the symptom of low volume is the same on battery or electric power cord. I just replaced the battery just now, no change.
by
@badmoon0007
That’s strange,perhaps opening it up may give us a better idea of what’s going on inside
Maybe have a check of all those capacitors as if one goes it can cause low volume and a short could cause a dip in battery life:-)
by
Add a comment
Add your answer
David will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 31
All Time: 629
