A2116 / 2019 / 3.6 GHz quad-core i3, 3.0 GHz 6-core i5, or 3.2 GHz 6-core i7 processor. Released March 19, 2019.
78 Questions View all
Can I replace the Fusion Hard drive with an SSD on a 2019 iMac? and...
Will it cause any issues with the way the existing Fusion flash blade recognises or communicates with the new SSD?
Is it necessary I buy and connect a Thermal Sensor?
Can I buy any SSD? or are there some which cause conflicts?
I appreciate any help.
Thank you
Score 1
Add a comment
1 Answer
The blade SSD is used as a cache drive to the 2.5" HDD when the two are setup as a Fusion Drive set.
When you remove the HDD replacing it with a SSD you will sever the Fusion Drive so the Blade SSD will just sit unused. The first versions of Fusion Drive used a 1TB HDD and had a 32 GB SSD for the cache drive, after August 4 it had a 256 GB SSD.
If you have the larger blade SSD I would recommend reformatting making it the OS boot drive as the PCIe/NVMe interface is faster than the SATA III (6.0 Gb/s). Sadly the small 32 GB drive is not large enough to do much of anything.
Here's the guide you'll need to follow to replace the HDD: iMac Intel 21.5" Retina 4K Display 2019 Hard Drive Replacement
If you can I would upgrade the blade SSD to something larger 256 is a good size for writing and simple web use with the macOS on it. Going with 512 or larger offers a lot performance! Here's the guide for it iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement
Otherwise don't worry about the blade SSD, just let it sit unused if you go with the 2.5" SSD.
iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Image
Guide
Difficulty:
Moderate
1 - 3 hours
iMac Intel 21.5" Retina 4K Display 2019 Hard Drive Image
Guide
Difficulty:
Moderate
30 minutes - 1 hour
Add a comment
Add your answer
James Rice will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 170
