changing temperature with remote
if i take my remote outside i can change the temperature setting on my split system but the remote is too far away from my air conditioner.
so my split system wont change temperature. yet my remote will say it is heating at the revised temperature.
will the air con automaticly upgrade to the set temperature when my remote gets near the unit. if not then how will i know what temperature it is pumping out.
this seems to me to be a bug with the way the remote works.
is there something im not getting?
shouldnt the remote not show a revised temperature when it isnt near enough to the split system reciever?
Add a comment
1 Answer
Most Helpful Answer
Hi,
What is the model number of the air con unit?
It may depend. With some air con makes/models they only show what the "desired" temp setting is i.e. temp set by the user and not what the actual temp is and the air con unit will regulate to get to the desired temp and then maintain it at that temp.
With others they show both (or have the option to view both, one at a time) i.e. desired temp and actual temp.
What does it say in the user manual for the unit regarding the temperature setting and display? Also just curious why you would use the remote outside for an air con unit as air con units are used inside? ;-)
Score 1
Add a comment
Add your answer
peter drury will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 110
