The Xiaomi Redmi Note 8 is a mid-range smartphone by Xiaomi released October 2019. It has a 6.3" IPS LCD display, a 48 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 665.
46 Questions View all
Xiaomi Redmi Note 8 Pro
Hello,
Recieved an Xiaomi Readmi Note 8 Pro water damaged phone. Removed all the shields and cleaned the board with ultrasonic cleaner.
1) Found out that VSYS line was shorted out (Found the badboy on the motherboard and removed) now VSYS is showings correct voltages.
After i put the phone to charger it is showing fluctuating "Amps" 0,15 till 0,48 and still cant be booted.
Voltages from some measured capacitors are going up and down continuously.
Add a comment
1 Answer
Most Helpful Answer
Hi @kapuzta
I don't know the answer but here's a link to the schematics for the phone that may help to find out what's going on. Apologies if you already have them.
Score 2
Add a comment
Add your answer
Kaspar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 200
