Repair information for the Creality Ender 3 Pro--an upgraded version of the Ender 3 3D printer, made by Creality. Released in September of 2018. Model number: Ender 3 Pro.
3D printer blue screen
Built printer, then it turned on. Leveled the plate to the print Nozzle with a piece of paper. I printed 2 test models then a 5 hour model. All 3 models we fine. Then turned off printer. The next day I turned the printer on and only got a Blue screen.
Score 3
10 Comments:
was the printer bumped at all?
by
No.
I did a puzzle tube print which took 5 hrs, when it was done I turned the printer off. The next day when it turned it on it had the blue screen.
by
ok, check the connections maybe. there is one on the back of the LCD and another inside the CPU
by
Are you using octoprint or an SD card to print your models? Try using octoprint instead on an SD card, I accidently inserted the wrong SD card and it corrupted the firmware. Try re-flashing the firmware , that usually did the trick the few times it happened to me. On one occasion the LCD connector was loose. good luck.
by
I checked all the connections before hand and then went through a lot of different things that others have said to do., nothing helped.
I just don't know what else it could be. It is brand NEW. I just got it and did 1 print job, turned it off after it was finished, next morning turn it on and got the blue screen.
by
Show 5 more comments
Add a comment
1 Answer
its 1 of 3 things u have a loose LCD or not connected properly it could be that u have attempted to mess with the power management by accident and now it's has too much/&or to little voltage and is ether broken or not working properly, or 3 it's something on the board that's needs replacing these are the most common things i run into
Add a comment
Add your answer
Frank Lovash will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 128
All Time: 3,759
