Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
114 Questions View all
Is my screen dead or is it a cable issue?
Hi all,
My apple watch screen suddenly went bright green/yellow (see video). The digitiser still works and the watch hardware is ok (siri will answer). If its the cable, then I'll open it up.
https://www.youtube.com/shorts/1yjp7Mj4h...
Sadly the cost for a 44mm replacement is more than the watch is woth.
Thanks,
Dave
Add a comment
Most Helpful Answer
Hi Dave
I quite hard to say but it could be a cable issue!
It could also be a internally damaged OLED display
I would open it up and reseat the cables in their connectors and if that doesn’t work it will need replaced
I never pay the price they want for them new so I get a iCloud locked ones and remove their displays as they cost waaaaaay less and it’s original quality. :-)
Hopefully this helps
Score 1
2 Comments:
Thanks, I'll crack it open later and see if I can reseat the cables. The watch has had a hard life if its dead its dead.
Thanks for the locked watch tip too, I've not thought about that.
by
@ds2000
Sounds good:-)
When you open it up try and use a curved exacto knife and use a hairdryer to melt the adhesive
It’s quite hard to get the screens off so if you need any help just give another answer and il try and help:-)
by
Add a comment
@ds2000 - Sorry guy, you do need a new display. The screens decode chip is on the back side which likely got liquid damaged here. There really is no cable to replace here.
Reference: Apple Watch Series 4 Screen Replacement
If you jump to Step21 the cable harness is part of the S4 SIP package which you can see in Step 11 in the Apple Watch Series 4 Teardown
Apple Watch Series 4 Image
Guide
Difficulty:
Moderate
Apple Watch Series 4 Screen Image
Guide
Difficulty:
Difficult
1 - 2 hours
2 Comments:
Thanks Dan,
I'll get looking for a spares watch with a good display. Im not paying more than the value of the current watch to repair it.
I was due to upgrade last year but the latest version was such a small step I didn't bother, I'd have probably gotten 150-200 euros for this back then and given it'll be the beating I give them with sport thats broken it, for someone else it probably would have lasted a few more years.
by
Hi David,
Having the same issue as you. Can you confirm that replacing the screen fixed the problem?
Thank you!
by
Add a comment
Add your answer
David will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 232
