Enquiry about Gem Real Piano RP800
Enquiry about Gem Real Piano RP800. There are several notes that are sticking down & will not return to normal position. What is the likely cause & Is this a repairable problem?
I have the exact same model of piano. I am able to get it fixed. It took me about 6 hours. The keys would not return to its up position after pressing on it. It turns out the white plastic that holding the weight of each key has expanded over time. The aluminum rod that goes through each weight is getting too tight for the weight to move (rotate) freely. Also, the expended white plastic is pushing against the side of the black case that holds the weight and the rod together.
To fix the issue, I did the following:
I need help with this exact problem I live in Wimbledon is there anyone in that area that might be able to help me?
Hi,
If you don't receive a better answer, it may be worth considering purchasing the service manual as it contains dis-assembly and repair instructions as well as a spare parts list etc.
Not sure if it is in the language that you require though. You may wish to check with the seller first, if you decide to buy it.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 20
All Time: 863
1 Comment
I have the same issue and was just told it's impossible to get parts for this piano and it probably can't be fixed. Not what I wanted to hear. :( If you do get it fixed, please post.
by cherylschrank
