Krups single trigger coffee grinder identified as style F203.
Information: Ancient Model Base
This is just an informational comment. My GF has been using this grinder daily since about 1980, and it has never been maintained. I suspect that the "0602" is probably the serial number, so it would be almost the oldest that you'll find.
I saw comments saying to remove 4 screws or clips, or remove the paper label to expose the slot in the bottom of the shaft. They don't all necessarily have those.
It does have what looks like two #2 Phillips screws retaining the base. They have about 40 years of rust on them, but it looks like that's all that retains the base.
So depending on the vintage of your grinder, the parts may not be exactly the same. Luckily, these devices are simple, with little more than the motor, blade, switch, and body. You may just need to do a little more work to figure out how yours comes apart.
I only came looking to see what I'm getting myself into before I break something. I kind of assumed that the blade was pressed on, rather than screwed on. I'm glad I looked, before I broke it, trying to pull the blade. :)
1 Comment:
Hi,
Maybe @vauweh might know.
Due to different time zones allow a few days for a response.
Moderator.
by
Add a comment
Sorry, don't know this Type from Krups. It seems that there are different versions of 203, depending of production date and country. I did not know, that they also had a factory in Hong Kong. Anyway, they are similar ," mas o menos". Perhaps this Krups F203 Coffee Grinder Motor Replacement helps. I think the blades are just pressed in. Good Luck!
Update (09.07.2022)
Did you see this videos:
and
On this device the blades are screwed in.
Add a comment
I thought I need a new.motor, but after I got it apart it turned out the contacts needed cleaning using a file or a knife to scrape off corrosion.
The contacts are easy to find....there's a kind of leaf spring with the contacts. The button is what closes the contacts when it pushes the long shaft down.
My Type 203 had no clips. It would be nice to find a replacement blade.
1 Comment:
Did you ever find a replacement blade?. I have the same exact one Type 203 from the 80s, part of the blade snapped off but it still works.
by
Add a comment
Add your answer
JW Smythe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 617
