Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
376 Questions View all
How to remove the Passcode with out losing data?
I’m the owner of the device and the Apple ID being used on the device I just forgot the passcode from it and it’s also currently with the “iPhone disable connect to iTunes ”sign from trying every number I could remember lol 🤦🏻‍♂️
Score 1
Add a comment
Most Helpful Answer
use 3utool and reflash with retaining user data
Score 1
3 Comments:
The device is in disable mode would I have to get the device into dfu mode for the device to connect to 37tools and follow your suggestions?
by
@taco18 dfu or recovery mode
by
@tech_ni thanks for your help I tried following the steps to get the device in DFU mode, then flash process maintaining user's data I still find myself in need of a passcode even on the attempt to retrieve user's data and once I use a passcode I believe it's correct the phone gets into an iPhone unavailable try again in some minutes. If there's anything you know I should do to get rid of the passcode please help once again
by
Add a comment
Put it into dfu. Recovery resets after 15 minutes turning the phone on losing the connection to pc, dfu doesn’t.
Score 1
Add a comment
Waimond michae
Update (11/14/24)
Sign out apple
1 Comment:
Sign out apple
by
Add a comment
Add your answer
Taco will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 144
